Thanks all - I communicated with Steve from Bevel Heaven and this our communication...
Please read from Bottom to top...
Looks like I need a whole Master as there are NO Brembo supplied 16mm rebuild kits....
DavidK
Absolutely - would be nice if you directly link to my site........ etc thanks
Steve Allen
www.BevelHeaven.com
www.Store.BevelHeaven.com www.Forum.BevelHeaven.com
925.798.BEVL(2385) PO Box 340 Concord CA 94522-0340 USA
www.twitter.com/bevelheaven www.facebook.com/bevel.heaven
-----Original Message-----
From: David Kirscher [mailto:drdavidk@IFE.comcastbiz.net]
Sent: Monday, June 25, 2012 10:48 PM
To: Steve @ Bevel Heaven
Subject: Re: Old Monster Brake probs...
You sir just ROCK!!
Thanks so much - Is it OK if I post tis onto a Ducati Monster forum site for all to see??
David
On Jun 25, 2012, at 10:40 PM, Steve @ Bevel Heaven wrote:
> Hi david, it's real simple to determine.. All your clutches are 13mm
> and use this kit here
https://store.bevelheaven.com/brake-related-parts/brembo-13mm-clutch/b
> rake-m
> |c-kit-fits-all-hollow-pivot-lever-type-mc/
> If your bike has only 1 caliper up front, then you use the same exact
> kit to do the brake as well.
> If your bike has 2 calipers, then you have a 16mm master cylinder and
> there is no kit available for you. Brembo doesn't/won't supply one.
> Luckily I do stock new 16mm Master cylinders for reasonable, see
> below, you can order with silver or black levers etc..
https://store.bevelheaven.com/brake-related-parts/16mm-rec-brembo-mast
> er-cyl
> inder-front-brake/
> Steve Allen
www.BevelHeaven.com
> Sent: Monday, June 25, 2012 10:23 PM
> To:
Shop@BevelHeaven.com
> Subject: Old Monster Brake probs...
> Hey -
> I found your site via a Ducati Monster forum - and there a couple of
> us trying to find Master Cylinder Rebuild kits for the "coffin" style
> Brembo Masters (both Clutch and brake).
> My bike is a 1995 M900 with the coffin style masters on both brake and
> clutch.
> Is the "re-build kit" for the 15mm Master the correct one for the
> Brake on my bike??
> How would I verify this??
> Thanks so much.
> David Kirscher
