101 - 120 of 234 Posts
Old fluid and header heat don't align with the symptoms I am experiencing. Old fluid won't cause sponginess when cold. Header heat causing boiling would cause sponginess immediately. I've never experienced sponginess in my rear brake when riding even before this issue manifested. I use my rear brake all the time.
It seems a little air got into the line from somewhere...but where? Flushing/bleeding may help but the symptom will return eventually.
FYI, I'm not against bleeding brakes or anything else, but the responses I find to be a bit over the top so I just have to tweak some of you guys.
Please read post # 23 and # 81. Look no further !
Bleeding is a yearly band-aid but not the cure.
Ducati is trying to avoid a recall across the board.
But don't believe every word from the fluid manufacturers (same for oil, tires, chains etc)
The information I posted was not written by the fluid manufacturer.
You will not find this info on Motul's website.
It was written by Dynamic Racing Solutions which is a high performance vehicle service center.
LOL - thanks DarR. I assume I would need to buy the brake line for a new monster then. Or I could just upgrade to steel braided lines (probably for about the same cost).
What you wrote is true and would solve it. The issue is that it's a really big job.
Your bike will look like mine in post # 23.
I was actually lucky as the change was erroneously done under a recall but then passed under a customer appreciation job.
OooOooh....what I really want to see is someone who has had the brake line fix run some cheap fluid in and report if the brake goes spongebob....again....that would be a firm data point.
The faulty brake line may not be an isolated issue. IMHO, there's no need to exacerbate the problem with 1) cheap fluid and / or 2) which has not been changed in a couple of years or more.
Just look at all the threads started about Monsters with rear brake problems.
Almost all are maintenance related issues.
Most riders neglect their brake fluid or use the cheapest **** they can find.
Its not rocket science, yet so many problems, and the solution is so freaking easy to fix.
How much proof do we need?
Check this out:
Another motorcycle ABS success story. Back to the good ol days when Brembo wouldn't sell you brakes unless they provided the whole system.
I don't know if there was a posting of this but Ducati issued a recall for the 1200S for the rear brake line. The Rs are not covered but my shop pulled some strings and made it happen. They replace the line to the ABS brain and the line to the caliper. The line from the factory had an issue where air/water etc could enter at the banjo/line connection. Updated brake line fixed it. I now have an excellent rear brake. Repair billed at 800 bux ....apparently a pretty extreme teardown is required to get to all the parts.
Now if my multi had a decent rear brake.
For those of you that are following this, I would strongly urge everyone to fill out a complaint form on the National Highway Traffic Safety Administration website to help them perform an investigation. Those of us stuck without a recall because we have a 2014 would really appreciate it.
Dar, I've read through this thread and can't come to definitive conclusion as to wether or not the 2014 Monster 1200 S has the same defective banjo fitting as the 2017+'s that were recalled. I'm ready to get it fixed properly. If the banjo is the problem on the 2014 I'll pay to have it replaced.
All I see ; is that there are more lawyers owning Diavels than Monsters...none of them capable of bleeding there own brakes...don't get me wrong, something is awry in the system...but the solution varies from model to model to what is an identical system with only subtle variations....it's taken me 5yrs to get a firm rear brake lever....and whilst it's taught now...every use has me questioning it's ensuing failure...perhaps it's my brand of socks[emoji3166]....I have to default to human error ...only because it does work... now....the only banjo problem I can think of is from deliverance
