Standard Accompaniments
1.5K views 15 replies 8 participants last post by  SHADOWCHASER
#1 ·
Hey people,
Just bought a used 2004 M620 ;D Will be picking it up this Saturday. Can someone please give me a complete list of all the standard items that come with the bike i.e. two keys, red key, manual etc? I just want to be sure the (present) owner does not miss anything.
Also, I was going to rent a standard cargo van (Enterprise) to transport the bike. Anyone has any experience hauling a bike in one of those? I will be using straps. Any pointers?
One of the problems I am facing is driving/loading the bike into the van. The van is about 2 1/2' off the ground and does not have a pull out ramp. Was thinking of just buying a 4*8 piece of wood from Home Depot. Short of buying a real bike ramp, does anyone have a more elegant solution?
#15 ·
Just bought some 2x12 today. Also picked up the Canyon Dancer harness and some tie-downs (Michael Moore's pics are a lifesaver). Have not been able to talk to the (present) owner yet, so in case they do not have a very bike-loading-friendly terrain ::) the 2x12 will be my backup (glad to know you do it all the time, Ddan). Got a 6' long piece, should give a gentle enough incline and another 4' piece to prop the front wheel against.
Anxiously waiting for Saturday. Again, thanks for the support guys. Got your number shadowchaser, will talk to you soon.
#14 ·
SHADOWCHASER said:
ashcap, You should be able to avoid the risky 4x8 routine by packing the cargo van in to a bar ditch or up-against a slight hill. an unsecured board could easily slip out or flip over and drop the bike if you got off center on it . If you absolutely must use a board make it a 2x12 and secure both the base and the top before you attempt to put the bike on it.
SHADOWCHASER ;)
I use the 2x12 ramps all the time, but I use one for the bike and one next to it to walk on.
#12 ·
SHADOWCHASER said:
[laugh] [laugh]Might be able to take you up on that beer as I am currently awaiting dispatch in Minneapolis, MN. and other than going to South Bend, IN. for some preventative service to my rig, I'm in limbo till the boss lets me know his plans sometime tomorrow.
I PM'd you  my cell #.
SHADOWCHASER
Hey Shadow when you are in South Bend gimme a call you'll get a beer or two. PMed the number
#10 ·
Awesome! Thanks for all the help!! Never expected this level of support [clap] Have not even ridden the bike yet but just this board alone makes me feel glad I bought a Ducati... ;D
Shadowchaser, I might just take you up on your offer. I am not the kind to pass up on a freebie [cheeky] ... ah well, maybe a six-pack if you are in or around NE Ohio ;) I will get in touch with the seller and get an idea of the topography around his place. Will pm you after that. Thanks again...
#9 ·
PM or e-mail me a good phone number where you can be reached and I'll be happy to walk you through it and answer any questions or concerns you may have.
SHADOWCHASER ;)
#7 ·
The code is meerly used to start the bike if the key doesn't disable the immobilizer. The process is outlined in the manual - it goes something roughly like: turn the key to on, twist the throttle full open and watch for the immobilizer light to flash the number of times of the first digit in the code, then release throttle and twist again to get the # of blinks for the second digit, etc.... I am sure that this is not the exact sequence since it was tricky and I didn't bother to look it up in my manual, but the code is something like that.
There is no way to reset that code to my knowledge, which is why it's important to get the card. The red key is the most vital though since you NEED it to make new black keys work if you lose a black key.
#6 ·
Thanks BryanS. In that case, is it advisable/standard procedure to reset the code?
Please excuse my ignorance! :-[
#5 ·
It has the code on it to override the immoblizer. Mine from my '03 is a gray card with a picture of a key on the front. The back is black and has the "electronic code" for bypassing the immobilizer and the "mechanical code" which I believe may be used for cutting new keys. As you probably know the red key is for making new black keys work with the immobilizer. I also got a little metal tag with my keys and it has the mechanical code etched on it.
#4 ·
Thanks guys. Hey Spidey, tie downs are a simple and neat idea. Now why did'nt I think of that before! ???
And what exactly is THE card?
#2 ·
One or two black keys (there should be two, but it's not a dealbreaker), a red key, and a card.  You need the card.  You can download the manual if necessary.  You should get a seat cowl and a windscreen with the bike--either attached or extra--unless it's a Dark.
Anything else, gang?
Michael Moore describes how to load into an Enterprise Cargo Van in the Track Day Prep FAQ.
The only problems I can see with a board are (a) if it can't handle the weight or (b) if the raised end slips off whatever it's resting on (that'd be messy).  Why not drill two quick holes in it so that you can use tie downs to hold the ramp in place while you load the bike?
