I want to upgrade the 800's suspension and brakes, along with most of the other bits up front, but I'd like to do things in stages. The problem is that if I buy clip ons before doing the suspension upgrade, to say 848 forks, I'll have to repurchase clip ons at the 53mm size because the stock forks have 50mm. So keeping the list below in mind, what are my options and what parts are needed...
848 forks
848 calipers
848 rotors
Speedymoto upper and lower triple clamp
Rizoma Reserviors
Rizoma grips
Woodcraft Clip-ons
Puig shorty levers
1. Can I use the stock front wheel and wheel fairing with this setup?
2. Can I use the 848's upper and/or lower triple clamp until I get Speedymoto clamps? (looks like the upper one just needs the front part shaved off to fit) Can I use the stock lower clamp or the 848 stock lower clamp if I replaced the top?
3. Do I need to find the 848's master cylinder too because I want to eventually switch to Rizoma reservoirs? What do I need to convert from the coffins to the Rizoma reservoirs and can it be done with the stock master cylinder?
4. Will the Puig levers work with the stock setup and this setup?
5. Could I buy 53mm clip ons and triple clamps while I wait to collect the 848 parts and just use spacers/shims?
Some of this is for aesthetics and some is for performance, so don't hate on me for the choices, or say I should just drop 2k on Ohlins. I'd like to buy clips ons, then top triple clamp, then levers/reserviors/grips, then install the 848 bits, but if I can use the 848's triples then I'll buy the Speedymoto's last. My budget is not dirt cheap, but if I can do some tasteful upgrades and have it come in stages without back tracking, so that I am not over-spending or having to drop 2-3k all at once for all this stuff then that would be nice.
Thanks in advance.
848 forks
848 calipers
848 rotors
Rizoma Reserviors
Rizoma grips
Woodcraft Clip-ons
Puig shorty levers
Thanks in advance.
