This one for the 2016 M1200R comes from Remus.
Check-out the numbers, especially for the stock exhaust :0
Can't you save it as an image or do a print screen of your charts?This is my dyno run. Monster 1200s-15 with termignoni slipon and upmap.
Never mind, can`t upload files as they are to big:0
Send me your email and i'll mail IT to you, then it's your problem:grinCan't you save it as an image or do a print screen of your charts?
Sure, send it, I'll see if I can find a way to post it under your credit.Send me your email and i'll mail IT to you, then it's your problem:grin
Thank you very much:angelJust received the chart courtesy of @Halvdampis
I would expect very little or no noticeable difference. The full headers may be slightly smoother lacking the O2 sensors and the exhaust valve but they're not any larger than the "R's". The reasons for swapping are for the farkle ( a pound less weight) and bling (shinny and blue).Will be nice to see a dyno chart for a full termi exhaust.
The 1200 R should produce 152 HP at the crank (corrected value for Europe), means about 140 - 142 HP at the rear wheel. This with the stock equipment. How do you use your SC-Project? DB Eater on board? Air filter stock? I'm really no fan of the Rexxer mappings. First of all there is no sense to kill the closed loop area. You can manipulate it (14.2 AFR instead of 14.67) without loosing the self-regulation effect in this area and nevertheless getting a smoother engine in the lower rpm range. Unfortunately the synerject ecu of the Monster 1200 isn't hacked till now so you have to use a piggyback solution or send in your ECU if you want to flash it (by Rexxer after a hardware manipulation). RapidBike keeps the closed loop area alive and allows the selective tuning of the parameters for each cylinder. Before any misunderstandings arise: I prefer flashing the ECU but not sending it to a dealer. I want to flash a new mapping and playback the original configuration myself.Just had a "for charity" dyno run on my Monster 1200R. Half the proceeds went to the Diabetes Foundation. Great Idea.
However:
SC-Project Carbon with Rexxer flash. Open loop only, O2 disabled.
140.11 HP Not happy.
Are you going to try a different tuner? I am thinking about going Shift Tech exhaust with Rapid Bike Evo, I like RB's stuff.Just had a "for charity" dyno run on my Monster 1200R. Half the proceeds went to the Diabetes Foundation. Great Idea.
However:
I just saw your edit and if I were you...I would just get the RB and call it a day. I agree 100%, there is a reason people like the RB units. That is the way that I am going, just waiting to see what black friday deals are to come then I am going to buy my Shift Tech and RB. The other plus for RB is that you can buy the Up/Down quickshifter add on.Rexxer got back to me. They usually can fetch north of 145hp but altitude, atmospheric changes and other subtle variances can make a difference. A competition air filter would add a few HP's although not recommended for the street. In addition to a clean air filter which mine may not be, they suggested to disconnect and plug the vacuum line from the charcoal canister to the intake if it's still on the bike. Disable the TC for the dyno run which I had. That's about it in a nutshell. They did remark that the dyno curve looked good which they felt was more important than the small peak power difference.
