Is Windex bad for clearcoats?
4.1K views 9 replies 9 participants last post by  TJR178
#1 ·
Ok so I just washed my bike and then it rained.
Now i have a couple of water spots and some specs of dirt on the tank and fenders. My quesition is can i use like a windex solution on the paint or will the harm the clearcoat.
I have done this before but ive always wondered if i should or shouldnt.
Any input would be great.....
#2 ·
For what it's worth, I have often used Purple Power (PepBoy's version of Simple Green) for a sort of spot cleaning or slight sponge bath. It helps me keep the tank and fairing clean without having to wash and dry the whole bike. I usually follow that with a light waxing or at least some detail spray.
I'm not saying it's good for it, I'm just saying I do it and I haven't seen any problems.....
#3 ·
i use meguiars final inspection or mothers showtime,spray on detailers,they lift bugs,water marks and other stuff fine and also bring a nice shine.i'm not sure how much wax or polish would be left after using household cleaners,they're usually a bit harsh on paint.but if you polish it regularly it should be o.k i guess.
#5 ·
I would use warm water to wipe it down with. I used to clean my helmet with Windex and the plastic vents disintegrated and fell out. I sent it to Shoei and they sent me a new one and told me not to use Windex on it. I use warm water to remove bugs and mineral spirits to remove tar, chain lube and brake dust. I use degreaser on the engine when I wash but I make sure it is safe on aluminum. Right now it is some orange stuff.
#7 ·
The worst thing for any finish is usually the piece of paper that's used to wipe it. Always wet your paint before cleaning. This acts as a lubricant to keep the dirt from scratching. Also use a cloth to wipe, not paper. Meguiars Final inspection is a great product.
#8 ·
Thanks for the info guys.. and no, I dont use paper, I use cleanroom wipes that i gank from work...Ill give the final inspection stuff a try.
