I messed up my left wrist about a year ago and ever since then, my wrist kills me after I ride for about 30 minutes. How can I make the clutch easier to pull? Is that what the slave cylinder does?
+1Norm said:You can also try taking out 2 springs.
I've been running 4 springs for about 4,000 miles and haven't had any problems either.2001cromo said:I've been running only 4 springs on my dry clutch for a while without issue.
Worst case your clutch will slip (test at about 60-70mph in top gear) and then you'll have to put them back. But I think you'll be fine.
Guy Martin told me about that little trick. I thought it was a great idea until I tried it (m900 w/ dry clutch btw) Clutch pull was heavenly. But. . . it slipped badly in the upper rpm range. Im running a stock basket and pressure plate, w/barnett alum. plates.Norm said:You can also try taking out 2 springs.
