Cleaning rubber off exhaust pipes
3 reading
1.8K views 12 replies 9 participants last post by  gnostic203
#1 ·
The rubber from my boots has baked on my exhaust pipes. Tried WD40 and turpentine with no success. Anyone know how to remove the rubber from the exhaust pipes?
#3 ·
Okay, this is what works for me, done it many times. While the pipes are very warm, I use a rag soaked in brake cleaner and rub with force-being careful not to breath the fumes or leaving the rag on the pipes too long as the heat will transfer to your hand [gloves help too]. Then after it cools, a good metal polish follows and WALA! clean pipes.
#5 ·
i have some spots from rain, and i do not know how to clean the Exhaust Pipes because they are matt finish, any product that i should use?
#6 ·
I actually tried the Tarminator and didn't do anything. What I found did work though was Turtle Wax Polishing Compound. I wish I had some of the Rubbing Compound though to take most of the rubber off first but didn't have any, so I used a window scraper blade and that worked great for taking most of the rubber off then finished off with the polishing compound.
#7 ·
umm, isn't brake cleaner flammable?
#10 ·
Sorry I haven't replied sooner, just came back from a five day bike ride up the west coast, AWSOME time. Anyway, yes brake cleaner is flammable to an ignitable source [flame], but the pipes when very warm will not reach the "flash" point [point of ignition from heat alone] of the cleaner. This is what works for me, I also heard that a friend of mine uses "Goo Gone"
#13 ·
Simple Green on the pipe works well for me. Warm em' up and let it sit for a minute or two before wiping. Whamo no more burned Doc Marten's.
