brand new. never used or installed.
2011 Duc.EE Ducati Exhaust Emulator - Servo Eliminator - 150 shipped. bnib
Installation: Unplug and remove the factory exhaust flapper valve actuator.
• Remove cable(s) to the actual flapper valve installed within the exhaust.
• Use the provided tywraps, doublesided tape or velco to install the DUC.EE as desired.
• Plug the DUC.EE into the factory wiring harness with the same style connector as per the factory.
• Turn on your ignition and verify your Check Engine Light (CEL) message is off.
Size: Box is 1.75in (tall) X 0.50in (thick) X 1.25in (wide) with a 3in pigtail connector to the factory harness.
MotoCreations Warranty: Five years as long as the Duc.EE hasn't been tampered with, tamper seal is not removed and the unit is not physically damaged (ala crash).
