I am looking for the following parts for my '06 S2R 800:
Instrument cluster
matte black seat cowl
front brake and clutch levers
Also looking for Dainese leathers size 38 US
PM me if you happen to have any of these to sell. Thanks!
- Taylor -
Why do you need an instrument cluster, or have I already asked this? You are aware that you can't replace your cluster with a used unit?
My instruments have been going haywire... the speedo sporadically sticks or winds up to 160mph and the tach sticks at 5000 rpm and then spins way past 11000rpm. I called my local shop and they told me I would need to replace it. I am aware I can not replace it with a used one but I have seen new ones going on ebay from time to time so I figured I would put the request out there to see if anyone has one sitting around.
Thanks for the offer! I actually ended up taking the front cover off and it turns out the needles were just a little loose (prob from previous crash). Snugged them up and it seems to be working fine now. If however, I continue to have problems with it, I will be sure to contact you. Thanks again for your help!
- Taylor -
You might want to check the clips that hold it into the pc board. The often break too. I usually reinforce them with hot glue.
