I am looking for complete/ partial footrest OEM/NOS (ie, not aftermarket, see pic below for the right footrest piece) assemblies (or partial) for the original carburetor M900/M750. Full list of Ducati part numbers below, but #1-14 are key, screws and nuts i can buy new if you only have the main pieces.
Let me know
Let me know
# | Part # | Description |
1 | 82410241A | BRACKET, RIGHT FOOT REST HOLDER |
2 | 82410231A | BRACKET, LEFT FOOT REST HOLDER |
3 | 46010381A | GUARD |
4 | 46010391A | GUARD |
5 | 45620091A | PEDAL, GEAR CHANGE SILVER |
6 | 46410171A | RIGHT FOOTREST |
7 | 46410181A | LEFT FOOTREST |
8 | 800062562 | RIGHT FOOTREST |
9 | 800062563 | LEFT FOOTREST |
10 | 45610461B | GEARCHANGE CONTROL LEVER |
11 | 11710281A | GEARCHANGE ROD |
12 | 84850011A | BALL JOINT, LEFT |
13 | 84850021A | BALL JOINT, RIGHT |
14 | 82711151A | PLATE |
15 | 80A053548 | PIN |
16 | 800062568 | SCREW TCEI M8X1.25X41 |
17 | 77910931A | SCREW |
18 | 77910911A | SCREW M10 |
19 | 00A053546 | FOOTREST PIN |
20 | 62567 | WASHER |
21 | 71210341A | BUSH |
22 | 74750101A | NUT 6MM |
23 | 763106N01 | NUT |
24 | 800060700 | SPRING. FOOTREST |
25 | 76510171A | RUBBER PAD |
26 | 85210651A | WASHER |
27 | 79912521A | SPRING |
28 | 70010491A | VIBRATION DAMPER |
29 | 74750011AB | NUT, LEFT |
30 | 88450031A | SPRING RING |
31 | 77350678B | SCREW |
32 | 59485 | WASHER |
33 | 84740021A | BALL |
34 | 88641161A | O-RING |
35 | 77050638B | SCREW TE M6X1.00X12 |
36 | 85250291A | WASHER 6.4X18X1.6 |
37 | 62584 | PLATE |
