1 - 17 of 17 Posts
Discussion Starter #7
Steve, The 796 are tapered fat bars, unless you have 7/8 somehow. Let me know.
Ssg, they are 7/8 and in newish condition? I'll pm you my email for pics
I have two of them that are taken off the new bikes to be replaced with rizoma
and also I have one that is CF and one Renthal.
Can you post picture of your bars ??
Didn't see one from the side. Lemme take it apart real quick
don't need to, I already figure it out, you are screwed for some reason they use 7/8 alu bars. so your choices are limited to finding used one from your and only yours model or using chromed one from older models. if you measure your top of triple tree fork diameter I can give you another option if you are lucky, just let me know what size is your top fork it should be about 50mm but its important that you get exact diameter
Discussion Starter #15
They are 50mm forks. I'm not going to go as far as changing the triple or risers though. I'll just get older bars and paint them. Thanks for the help, man.
1 - 17 of 17 Posts
