Need a replacement for my 01s4. Would like one that is pristine but will concider repairable any color. thanks
Make sure that you see a picture of the underside of the tank before you buy it.
I made that mistake before I realized that all FI tanks aren't the same.
The size of the indention in the tank that wraps around the airbox and battery comes in two variations.
Tanks with the smaller indention (made for bikes with a vertical battery) also have a fatter vertical section on the left side of the tank hinge which hits the side of the vertical cylinder head on water cooled engines.
