I just installed a clear alternatives integrated tail light and am about to chop my tail. I hooked up my light and everything first just to check out it and when i have everything put on there are wires that hang down from the back of the light. I run it without the hugger on and am wondering if I can move these wires or if I should fab up some kind of cover or something for it?
Once you chop the tail, all the wires will be moved a bit and all the connections will be protected by that platic shield that sits in the bottom of your frame, avobe the rear wheel.
if you're really paranoid, you can get some shrink wrap, self sealing electrical tape and liquid 'electrical' tape and seal is all up.
