December: Install FCR 41s -- yes, I gave up on the jet kit. Expect the '41s this week; Chris from CA Cycleworks has pre-set them for my wierd exhaust, and I'm getting a lambda sensor for the header, so I can fine-tune them if necessary. Anybody wanna teach me how to do wheelies?
Enclose, insulate, repaint and heat a 16' X 24' section of the shop.
January: weld up a 4' X 8' X 18"metal work table w/ ramp.
Disassemble Monster. Powdercoat frame silver. Have billet supension arch fabricated. Reassemble w/ custom wire conduits, wire and hose clean-up, etc.
February: Disassemble Paso. Clean fuel system. Check engine condition; adjust valves; fix otherwise as needed. Replace tires. Clean brake & clutch systems; replace pads; replace clutch pack if needed. Check/adjust bearings. Strip lights/mirrors off of front cowl; remove/fill headlight opening; repaint cowl, install number plates. Install frame & rear sliders. Reassemble, tune, take to track on a warm day for a test.
March: Begin '35 Ford Sedan Delivery hot rod project. Open night club in Manassas.
If anyone wants to come by and hang out, there will be a stove and 'fridge, so various forms on non-moto indulgence will be possible. The night club will offer the same, but in the evening and you have to buy stuff -- no BYOB. Yes, I'm serious about the night club.
