Hi guys, gals,
Will the front forks of the following: 748/749/996/998 with 53mm outer tubes fit my '05 Monster 620 Dark? Yes, I will upgrade my brakes too.
Want to upgrade the suspension all around, but not enough $$ to buy new; can buy uses and rebuild to fit me [190lbs no gear, very seldomly 2 up].
Thanks for any 4-1-1
Discussion Starter · #2 ·
BUMP ....
Need help.... one of my forks is too bent to repair, need to buy both.. PLEASE!!!!! :(
I am just shooting some general info as i obtained before
someone correct me if i am wrong
sbk forks require you to replace the triple
you need to change to 53 top as the 620 takes 50m now
and you need shim for the bottom,
your bet would be st2 st3
s2r 1k , s4, s4r etc.
there should be plenty of threads about this
go search for it..
hope it helps
eric.
