http://cgi.ebay.com/ws/ebayISAPI.dll?ViewItem&item=7901311398
These were originally meant to go on a Confederate. I have been told that these may actually fit a stock Ducati but I personally have no experience with Ducatis. The inner diameter of the wheel bearings are about 20mm and it's got the 6 bolt pattern for the rotors at 40mm apart. hope that helps
if they arent right, you could probably swap out bearings and make them fit without too much drama.
alum. marchesinis arent worth all that much. maybe 7-800ish
i think your 00 had a 20mm front and 17mm rear
