Re: Will a '99 M900 Headlight Fairing fit an '01 M
The '99 headlight fairing has heavy brackets that bolt to the top tripple pinch bolts.
I believe the '01 M750 still has the same top tripple (the ones without cast-in risers) so I'd day "yes" it will fit. The only problem would be if the headlight bucket is positioned differently. To my knowledge, it is not.
I would think you'll need longer pinch bolts though I've never tried removing my bracket so I'm not sure.
