Cookie1 Kit & Clear Alternatives intergrated light kit. Installed both tonight. Cookies1's kit is great. Very easy to install with clear instructions and fine quality parts.
The Clear Alternatives kit was easier than I thought it would be to install. Advice- do not bother to buy the optional turn signal flasher. No need to install the resistors or the flasher unit. The stock flasher unit regulates a perfect pace for the blinker. On my 695 anyway.....
A few good choices however it's subjective in the end - certaily it's easy enough to build yourself if you have the time and means but few will match the qaulity of the Cookie kit which is thick gauge stainless.
The Cookie kit rocks (for me) because it's the cleanest - I just bought the Buel lens (<$10) for night time plate illumination as did not want an additional light as some kits have. I didn't even use bolts - just quality double sided tape with adhesive white reflective circles to coverup the plate holes - clean clean clean! lol!
I just did mine using the old light bracket cut and spun around 180. Drilled holes in it and bolted it into the existing holes for the splash gaurd. Total cost was 9.92 including some LED turn signals from checkers. took about an hour after I got the parts. I think it made my bike faster too.
Yeah , I think the best one is the one you do yourself .... 8)
I looked around for one that would do what i wanted but nothing out there would .. after many months designing it I finally come up with one that holds my exhaust , number plate , lights , and covers the frame ends. also has an under plate section all in one .... [thumbsup]
This is the latest version ..... I have no pics installed as yet
but ,
I have the older one that's in this pic spare .... It's made from 3mm mild steel and is only slightly different to my current version made from aluminium....
I just installed the Competition werkes kit no problem, but that mad doctor kit looks sweet wish I had seen it first. I really like the turn indicators (signals).
