1 - 18 of 18 Posts
Hi, I've been having an issue on my 2013 M696 after my timing belts(140/165hz) were replaced at the Ducati dealer. At around 3000-4000 rpms there is a whirring sound like a supercharger. Re-did the tension to 110hz and the sound is still there. Here is a link to the sound that someone else posted for their M695 but is the exact same problem I'm facing. Do I need to worry or is this something that is normal after a new belt change?
https://youtu.be/-Nnhm6NX_y0
I just had this problem fixed while i had a belt service completed on my 09 696. Its caused by worn out bearings on your cam belt tensioners. Have them replaced and your noise will be eliminated. The paets cost appx 64$ ea.
Discussion Starter #4
Can anyone else confirm which cam belt tensioner? The fixed ones or the movable ones or both?
There are 2 adjustable and 2 fixed belt rollers. After removing all the parts necessary to access the belts, you would of course change both the fixed and adjustable rollers. Like i stated before, these parts are not that expensive so change all 4
Discussion Starter #6
Thank you again! xD
Had exactly this same sound, and just like yours, while rpms coming down.
Changed every thing, with original parts, same sound, so f##$ it. Rode all summer no problems.
Just part of the charm i guess..
Sent fra min SM-G960F via Tapatalk
You can buy the tensioner bearings at any bearing or industrial supply store for under $10 each . Buy good bearings. The bearing number is on the side of the race, etched very tiny. I paid $6 each on eBay for SKF.
Hello mate, having the same sound, all 4 tensioners were changed and new belts set at around 100 Hz, same noise. Have you got any problems by now?
Here is my sound
HI mate, have you resolved this issue?
Having the same sound
Discussion Starter #11
I changed the movable tensioners and re-tightened the belts to 108Hz. Rode it a few thousand kilometers and its all good. Still hear the sound slightly though, abit more when the engine is very hot. I have heard that exact sound on brand new bikes as well so I guess its normal.
It is on mine as well.
Changed original bearings twice, no change. To little and not heat resistant grease in, the bearings i think.
My 2cnts.
I took mine to the dealer. They said it wasn’t a warranty issue, and I couldn’t come back until I take the playing cards out of my spokes.
So guys, in conclusion, these ducati belts are kinda acoustical and if you have not tensioned them beyond 140 Hz like ducati recommends, nothing to worry about
From reading about this for a while, I think some belts whir more than others, some bikes whir more than others, and adjusting the tension can have an effect on how noisy the belts are. Additionally, different brands prefer different tension settings. I think ear plugs may be the best answer.😁
1 - 18 of 18 Posts
