S
Superbeast_S4
·Guest
Hey fellas,
What do you recommend for a aftermarket rear shock/spring? Ohlins? Penske?
I ride a 01 Monster S4, and after 31,000 miles the rear suspension is shot. The spring is at maximum tightness (which isn't holding anything up anymore), and as I am using more compression to compensate, the shock itself is also on it's last leg.
Given this oppportunity, I'd like to sharpen up the suspension a bit. Basically I need to know the best way to go about doing this. I've already searched a few websites and plan on asking around at a few dealerships this upcoming weekend. However, if you guys have any suggestions (links to sites, etc) on where to look, give me a holler. Also I'd like to know what you all did for your bikes, as I can learn from your experiences, I'm sure.
Thanks in advance!
Thanks in advance!
