I've seen pics of others who apparently have it installed under the seat, right by the gas tank, butI can't find mine. Anywhere. I'm trying to install the replacement I got from electrosport. It should look pretty much the same right?
Look above the horizontal cyl behind the bottom triple.
Thanks, it was right there
At least, I hope that was what I yanked out... ;D
Aluminum housing with several fins on it. Wired by 2x red wires, 2x green wires, and 3x yellow wires leading into two connectors. held in place by two bolts fed through the housing at opposite ends. measuring about 3"x4".
