i just got this bike 2003 monster 800ie
and when i braking
just shake a lot....><""
can anyone tell me what 's happening...
It shakes when you press down the front break, back break, or both? Does it also make a sound?
One or both of your front disks could be warped.
Put the bike on a front stand and slowly spin the front wheel. If you hear the disk rubbing the pads at a specific point with each revolution...it's warped.
A worse case scenario is that your steering head bearings are shot and allowing for back/forth play when you're braking.
Most likely...it's the disks.
Discussion Starter · #4 · (Edited)
it happens when i only using the front brakes.. it doesnt make sound
but when i using both front and rear
it 's better...but still shake a little
