1 - 10 of 10 Posts
probably some sort of smog cannister mounting point for an earlier iteration of the Monster, a vestigial remnant...like the coccix or appendix in a human...no longer needed but still hanging around
The coil is mounted on the inside, behind the frame. Thats doesn't explain the big bracket with two holes for bolts on the outside???
??? MYSTERY BRACKET ???
Discussion Starter · #10 ·
You can just make out the coil (black) on the inside of the frame. That doesn't explain the two large mounting points on the outside does it?!?!?!
It looks like you could mount a remote resevoir for an after market shock on the outside of the frame. Or maybe a smoke machine to help you get away from police pursuit cars?
MYSTERY BRACKET!!!
1 - 10 of 10 Posts
