1 - 9 of 9 Posts
I am trying to figure the weight saving of mag and carbon wheels.
What is the weight of stock M900 wheels?
17X3.5" and 17X5.5" 2001 M900ie
Thanks!
Thanks!
... of course, you can use calculus to figure it out if the OEMs are made of steel... but maybe just email Ducati and find out.
on another board alex o. has posted weights as follows ;
bembro alum rear 13 lbs.
bembro alum front 11.5 lbs.
marchesimi alum rear 12 lbs.
marchesimi alum front 9.2
I've got quite a few stock wheels in my collection, if it's important to you, I'll weigh a few & give you the highs & lows. Let me know. As for deciding if lighter wheels are worth it, they are. It will absolutly transform your bike, buy the lightest wheels you can afford. If I had the money, the BSTs would be at the top of my list.
PS: The current issue of Sportrider has an excellent article on aftermarket wheels.
I couldn't understand why the survey didn't list BST wheels.....
then I figured out that BST stands for Blackstone Technology.
They're there.
motowheels lists this for BST's:
Street CF Wheels (including 6000 series alloy hub, stainless steel fittings with bearings): Front: 4.62 lbs; Rear: 5.94 lbs.
WOW! The BST are amazingly light but too expensive.
Norm,
If you have the time and are curious yourself, I think everyone here would like to see actual weights of our wheels posted for reference.
Thanks!
OK, here we go, these are random weights taken with a 25# hanging scale. They should be accurate to at least 1/4 lb.
rear stock 916 13.1# 5.5"
rear stock ss/m 17.3 5.5" w/rotor & bearings
but no cush drive
front stock 10.9 no bearings
front stock 11.2 w/ 25mm bearings
front stock 11.3 w/ 25mm bearings
front stock 10.6 w/ 25mm bearings
rear stock 916 13.0
rear stock 916 12.8
rear stock 916 12.5
rear Dymag 916 8.6 6"
rear Dymag 916 9.4 6.25"
front Dymag aluminum rim only 5.5#
front Magic carbon rim only 1.5#
front Magic 8.0# w/bearings
front Hipoint mag 7.5 w/bearings
rear Hipoint mag ss/m 12.9 5.5" complete xcp
rotor & sprocket
front Suzuki stock 10.1 w/bearings
rear Kawasaki stock 13.7 5" with bearings, no
cushdrive
rear PVM 16.5 x 6.25 22.7 no bearings, w/ 195
Dunlop 555 slick
160/60/17 used Dunlop 207 GP 11.0#
All the 916 stock rears were 5.5" - no, you can't buy a Magic wheel (I developed these myself) - feel free to write me for any other questions. [email protected]
1 - 9 of 9 Posts
