Was going to resurrect an old thread, but the site says I should consider creating a new one, so here we are...
There's a FB Marketplace ad for a conversion kit. The seller indicates it is reversible and requires no special tools. Seems pretty legit. Had I not already picked up a new basket for the S2R, I would've given this a go as I hate how quickly the oil gets dirty and [insert other personal preferences that aren't up for debate here].
Has anyone else made the jump with this particular seller?
Anyone with an S2R want a new basket at a discount so I can give this a go?
i picked my 800 over the 1000 to get the wet slipper clutch. scratching my head here
Different strokes for different folks? I personally like the clamor and haven't been happy with the slipper engagement, but then again, I've never ridden with a dry clutch and this one probably never had a good wet one (got it used at around 33k miles). I only recently learned about the cush drive after trying to figure out what blew up in the case.
Opened her up, found a detonated spring. Pulled the basket, found both of the remaining thick springs broken, two of the loose springs under compression, with the 3rd looking to make a break for it.
Perhaps I'd change my mind after swapping to a known good basket, but given the opportunity, I'd like to see how the dry works out.
Textile Headgear Material property Font Personal protective equipment
who doesnt love the clang clang of the plates but slamming down gears heading into a corner, the slipper clutch has keep me safe on more than one occasion. way fun. Oh but in all fairness i purchased my monster as a commuter and wanted ease of use for sitting in hot standing traffic.
I was just thinking why change a better clutch for a more primitive one. I do like the tink tink tink of my dry ducati clutch though. You can also install a dry slipper clutch. I did this to mine because might as well make your baby run better.
There's a kit for that? Do you have a link?
Figured I might as well just restore the bike back to proper, stock condition and see how it goes. After a test ride, I can't say there's really any difference from before. There always seems to be a sort of lag in power delivery when accelerating hard from an upshift. Having pretty limited experience with bikes, I can't tell if this is normal. Friction plates were within spec (3.4 mm) and I gave them all a flat 600-grit once-over for good measure.
