1 - 9 of 9 Posts
do a quick search on headlight mods... there's a U shaped bracket that needs to be cut, and you mount the gauges under the top triple...
Raiden is Solidus' son. I might be mixing up games but Liquid gets killed by Solid but Liquid's hand survives which is later used to control Revolver Ocelot because Ocelot's arm was cut off. I also know that Liquid or Big Boss was trying to make some army which used nano-machines to null emotions. Also, the Patriots are an orginazation that rig the US elections and want money and power. They have also kidnapped someone's daughter for some unknown reason. Also, Ocaton helps Solid with gear and weapons.
Patriots don't rig electios you big silly, they rig football games by listening in on the other teams calls. And Brady didn't kidnap anyones daughter, he simply married her. Sheesh. If anything, he is the one "kidnapped". Have you seen the poor guy running her errands?
BTW, does coach have a Ducati, or did you login to the wrong forum this morning?
Looks great, but, remember, if you like it then it's OK...
1 - 9 of 9 Posts
