·I have a new 03' 620ie with just about 1000 miles,that has this weird problem:
When doing cold starts, with the Choke in, the starter motor gets stuck at times and keeps going (note : the start button doesn't get stuck, only the starter). I have to turn off the ignition to get the starter to turn off. I did check the Engine cut off switch when this happens and its always in the correct ON state.
Then i try it again, and the machine fires up just fine. Is this a relay problem? How easy is it to replace the starter relay.
The weird part is, this has happend to me only twice, and i use the bike everyday. This has never happened when the engine is warm, just after a ride.I wonder if this has happened to anyone else out there, I am just worried that the machine would start doing this consistently.
-Spaceman.
-Spaceman.
