Does anyone out there have their S4 disassembled right now?
If so, could you possibly weigh the following parts:
Top triple clamp
LH riser/bar assembly
RH riser/bar assembly
Anyone out there have the CycleCat risers that would be used with their triple clamp on an S4, or know their weight?
Reason for asking is that I am looking at possibly replacing the above stock parts with:
CycleCat top triple clamp (1lb 9.3oz)
CycleCat risers (LH and RH) (? lb for the pair)
CycleCat adjustable clip-ons (1lb 15oz for the pair)
Jim G
Discussion Starter #2
Re: Weight of stock & CycleCat S4 triple,riser
I received some data from Alfred at CycleCat today:
DTC7 top triple: 22 oz
DBR23 risers & clip-ons: 45 oz (includes bar sliders)
Therefore a "complete" CycleCat triple/riser/clip-ons set for my S4 weighs 67 oz = 4lb 3 oz.
Anyone know what a stock S4 triple and combo risers/bars weigh?
DRS33 rearsets: 56 oz (includes all parts, including foot pegs and levers- note the stock brake & gearshift levers not used)
DEH3 passenger mounts & pegs: 25 oz (includes both brackets and footpegs)
When I weighed my LH rider and and passenger footpeg assermbly recently (2 lb 15ooz), I foolishly did not weigh the gearshift lever nor the rear brake pedal from the RH side, so cannot do a compaison.
Anyone know the weight of the stock rear brake pedal and of the gearshift lever?
Jim G
My stock bar/risers are currently out on loan..if you're still short on that info when I get 'em back, I'll weigh 'em.
I don't imagine the CC bar setup is any lighter than stock, seeing as there's more parts and fasteners. I've got the tall CC bars, bought 'em for the comfort only..........
Discussion Starter #4
Speeddog830: Thanks for the rescue on the weight of the stock parts!
I'll look forward to getting that from you!
Jim G
JimGnitecki,
I'm just about finished with putting my bike back together from my winter upgrade (slipped a 996 into my '02 S4). I have a bike trip to Canada next week, but when I get back I'll be tearing the bike apart again for another upgrade (single sided swingarm). I plan on doing a butt load of stock part weighing. Strati has graciously offered to swing by with a digital scale to get some weights on various bits.
I should end up with a pretty inclusive stock part weight list in the end. I'll add the gear shift and brake pedal to my "to-weigh" list. Probably be two weeks before I got numbers though.
Discussion Starter #6
JM-996S4: Thanks! Working together, we can build a formidable library of information that everyone can benefit from.
Jim G
