Hands off my Monster consistently leans to the right. Is the Monster generally unbalanced? The only obvious asymmetry might be the larger single disc brake on the left side. Possible related mod: rearsets (seem to be adjusted correctly) and steering damper mounted on the right. Tires: front Mez-3 and rear Pirelli Diablo (recently mounted).
Accurate ways to test this? Anyone added weights?
I think it's most probable that you have a slight misalignment of the wheels. Likely it's the rear, as the hashmark plates are quite a loose fit on the axle.
