Remove headlight by loosening the screw in the bottom of the bezel. The screw does not come out. Remove headlight. Remove bulbs and connectors. If you feel brave, remove the lens by removing the springs that hold the reflector in place. Assemble in reverse order. Do not touch the headlight bulb. If you do, clean with alcohol before installing.
ATO Memphis said:
This is silly.
Clearly "Headlight Fluid" is meant to be a joke.
Much like muffler bearings.
You don't actually add fluid to your headlight housing!
[cheeky]
that reminds me, i need to go get more halogen fluid
