6'3" @ 215 US size 12's here. Love my Rs! >
Shemonster and I even took her little 620 from the restaurant back to the hotel in Ouray with no ill effects from the short jaunt.
Although I'd highly recommend going with heavier springs for the forks and the rear shock if you plan on carrying anything but yourself on a regular basis.
Pushing the Rs hard on a rough road I managed to get her stock Ohlins to bottom a couple of times riding solo. (Stock springs are setup for a 160lb rider.) I added 250lb aggressive springs front and rear and the Sag is perfect for me now. [thumbsup] (Heavier fork and rear springs will run you in the neighborhood of $250.00 USD.)
The stock exhaust "s" pipes on the S*R Monsters will cause you to splay your right heel out slightly when riding on the balls of your feet with the stock pegs. Not uncomfortably just a little awkward.
I rode my 04' S4R for two years totally stock so its not THAT bad. As others have stated you can change to an adjustable rearset/foot peg or you can change the exhaust which most folks do anyway. >
