W
well_armed
·Guest
I just got back from my local dealer, a customer ordered the S4R Termi kit (carbon fibre cans) and didnt claim it.
Is it worth the cash to get all of it?
Any pages that I can read about the specs of these? Any local vendors (US) that sell these? What db are they?you own a 04 S4R, sil moto makes what i would say is the best looking full set of pipes for the S4R. arrow and termignoni or DP. here is a page from spareshack with the exhaust that they sell. http://www.spareshack.com/cgi-bin/browse-no-frames.cgi?session=36683782&view=group&group=ducs4rexh
Is noise an issue?
stock system's header tubing is 40mm diameter. that's pretty lame for a 996cc motor! it wouldn't work on an s4R but i installed a stock header off an st4 which is 45mm and made some custom cans with 50mm tubing and 748 muffler bodies with 52mm cores. saved over 10 lbs compared to stock and am definately getting better power out of this "kit".
go to ducati.com and do a bike comparison between the s4R and the st4S. virtually identical motors but the st4S has 45mm headers.
with a full system, you'll get good power, you'll save even more weight than just slip-ons (because you'll be getting rid of the "bulge") and it'll look much cleaner because there'll be no "buldge".
i'd suggest looking into the full sil motor or arrow system. costs less than the DP slip-on kit. with the money you save, cut your own airbox lid for free, drop in a BMC or K&N filter (DU-9001) and buy a PCIII from FBF with an appropriate map pre-installed.
well_armed:
same borexstrokeWhy is this...I expect you to know...and what can be done. Is it that big a difference performance-wise?
Just had the S4R Termi kit carbon fibre cans Slipon fitted today, they look and sound unbelievable, even with the cat, was going to have it removed but after hearing them, I
