Is it possible you have a tight closer? That would bind things.Adam in MO said:
Is it possible you have a tight closer? That would bind things.Adam in MO said:I'm finishing up my valve adjust, and when moving the vertical cam by hand, it's movement isn't nearly as smooth as with the horizontal cam. I'm assuming that something needs to be replaced.
Should I look at bearings? Valve guides? How do I narrow down the problem. I have the desmotimes book, but it's been of very little use in diagnosing this problem.
TIA,
Adam
+1 on ducpainters recommendation. When I did my 851 there was a difference of a couple of thousand between old and new halfrings.Adam in MO said:I guess it's possible that my intake closer is too tight, but I sanded it to about .0005" smaller than it was supposed to be (by my initial measurements).
I did replace the 1/2 rings though... how much of a difference is possible between worn and new 1/2 rings?
*the original 1/2 rings didn't look all that bad, but I figured they were worth replacing while I was in there, so...
Yeah, there can be a difference there. If you were shooting for zero on the closer, it's possible the new half rings have eaten up all the clearance you thought you had. Check the closer clearances again...Adam in MO said:I guess it's possible that my intake closer is too tight, but I sanded it to about .0005" smaller than it was supposed to be (by my initial measurements).
But if you put them in upside down (they deform in one direction) youll be in the same situation.Ddan said:You could just put the old half rings back in. The new ones are gonna deform until they look like the ones you took out and you'll be loose again.
