Turn signal/harness problem
4K views 1 reply 2 participants last post by  jamestcurran
#1 ·
NEED HELP
Hey y’all. So on my 2015 1200S, my right front turn signal has been out. Figured it was a bulb, swapped it with one from a rear light I took off a few years ago. Didn’t work. Kinda just dealt with it and had other projects.
Today I was installing NRC Rage360 turn signals. Right side won’t work. Hooked the new light to left side and it works so not new turn signal. Removed the headlight to trace the wires. I pulled the turn signal extension out and then set the NRC wires in to where it plugs into the harness to see if any power was coming through it… nothing. I don’t have a volt meter so putting the wires to wear power should be was my option.
Nothing else doesn’t work on the bike. Well the horn but that’s because I removed it.
The wire or part of the harness in question is labeled DX (right front) while SX (left front) works fine.
Where do I trace to from here. They are on the same fuse so it can’t be that right?
#2 · (Edited)
NEED HELP
Did you say you removed the rear turn signals completely, or did you just replace them with new ones?
Does the rear right turn signal work? Have you tried plugging the new bulb (from the front right) into the rear right, to see if it works then?
Looking at the wiring diagram (attached is for 796, but my guess is it's representative), it seems like both the front and rear RH are on the same circuit.
If the rear works and not the front, then it's something in the wiring on RH/Front indicator side.
If neither work, then it could be on the switch side.
