1 - 11 of 11 Posts
what are your thoughts on tpo parts smog removal kit is it worth 14.99 and do the instructions work for a person who wasnt born with a wrench in his hand.
worked for me...
Worked for me too. One note though.........DO NOT throw the nipples (for lack of a better word) away when you remove them from each of the intake runners to plug them with the supplied parts. If you ever want to sync the carbs in the future you will need them.
I just bought some rubber caps to place over the nips. I had some old spring type fuel clamps to place on the rubber caps. has worked great for several years.
... for those of us without a dremel tool: you can buy little washer/spacers to put on the M5 bolts so that only the appropriate amount of threads go into the throttle body. Thoughts about loctite: use the blue stuff and be careful not to let any of it get into the TB. The M5 bolts will need to be removed to balance the TBs at tune up time. (maybe a tiny lock-washer would be better)
Discussion Starter · #10 ·
Thanks I knew it would just be a split and bolts what I really needed was the diagram telling me how. Thanks for the suggestions. I have one more question does anyone know if this voids warranty from Ducati ?
1 - 11 of 11 Posts
