1 - 12 of 12 Posts
The speedo on my 696 was working intetermittently. Probably the poor connection next to the rear electrics connector down near the end of the brake pedal. Pulled up at lights, gave a quick prod around (this has worked before!). Without warning, everything shuts down. Everything. Is it possible I did this, or just a coincidence? Getting it home is going to be problematic at the moment, though it's not far away. Anything I should check? I know I'll have to check battery connections and earth but any other ideas?
Check that the harness is fully connected to the ECU and back of the instrument panel. Very wierd problem, how old is your battery?
About 8 months! Will check the things you advised . Just that the weather is crap, the bike is on a busy street a couple of miles away and you have to dismantle most of the bike just to get to the batterry!
Is there another fuse aprt from the ones in the little plastic box accessible from outside?
If you have a multimeter it might be worth checking the batt voltage too. The only connection near the brake pedal is for the rear brake lights and the oil temp sensor. Unless there is a short I don't think that is your problem.
well, yes, it's possible, as said, there may be a problem or short near that connection and messing with it blew the main fuse.
If the main is in fact blown, take a couple of new main fuses with you, if it blows again straight away, then try disconnect the plug you were messing with.
especially look for bare or broken wires touching. If it remains intact (fuse) then leave plug alone.
At least get it home. easier at home than on a street to sort it out.
Thanks, that's very useful. I'll look for this fuse. Under the seat? Is it a standard, easily available fuse? 30 amp? If that's just the issue, I could get the bike going!
Discussion Starter · #10 ·
So I arrived at the bike with a bag of tools then realised I'd not brought an assortment of Allen /hex keys for the tank. Ended up having it recovered to my garage and YES, it was the 30 amp fuse under the tank! Damn silly place to put it🙄. Thanks for everyone's help.
Next step is to make sure you know why it happened so you aren't stuck in the same position again. Do you still have the bad fuse by chance? a picture may give us more info to work off of
Discussion Starter · #12 ·
Unfortunately I threw it away. I think it's to do with the speedo/ rear light / brake light connectors. I was fiddling with them at the time because the speedo connector's been unreliable since I got the bike, but I can't tell why. Thanks for the offer, though.
1 - 12 of 12 Posts
