i'm going to go with "too much oil."
crack that drain plug open, and bleed 'er out a bit. should fix your woes.
or it'll at least help.
I don't ever get 4 qts in the case, more like 2 1/2-3factorplayer said:And I thought that mofo was supposed to take all 4 quarts.... what gives?
Bikes a 620 with fuel injection, No carbs therefore no float needleswzuccarello said:Better smell the oil . It could be fuel leaking past the petcock and carb float needles ending up in the crankcsae.
My Monster started doing this. Had to change the oil twice in a week because of dillution. The remedy was to install an in-line fuel shut-off valve on the right side near the carbs.
Fuel dilluted oil will wreck the motor if run for very long.
Wayne
