today i performed an oil change on my 2006 monster 620. The owners manual calls for 3.1 liters or 3.27 quarts. I let the old oil drain completely I poured 3 quarts and then 1 cup extra. The oil definitely didn't top off in the bike, i think i could have poured in some more.
After inspecting the side glass, the oil seems to fill the complete window when the engine is on or off. I feared that too much oil was put in there. Anybody have any experience with this? Should i siphon out some of the oil? Thanks in advance.
Oil used, Mobil 1 10w-40 full synthetic
It sounds like you have too much oil. It should be leveled between the 2 lines next to the window. Had same problem on my Multi 620 after the first oil change I did myself. Just drain some thru the drain plug and you'll be fine.
Good luck and safe riding
