Timing Belt Decibel Measure
708 Views 5 Replies 5 Participants Last post by  Beetle
Does anyone use SLA Lite to measure belt tension, if so how do you measure the specific sound of the belt, not everything else?
Firstly, never heard of SLA light, is it a sonic sound tool?
The engine is not running and the workshop must be quiet. The belt is then 'strum', as you would a guitar string. both sides of the belt.
Imagine tuning a guitar, as you tighten the string, the note changes.
I have always just used the 5mm vs 6mm allen key method as a base on older single cam engines, only using sonic methods for later, 'high end' or customer requests.
Both methods with video's explained here.
scroll down to watch video's.
  • Like
Reactions: 1
I use a guitar tuning app on my laptop plus a separate microphone to capture the sound. I've found it to be very easy to adjust the belts on my S4RS to nearly exactly the factory spec. Just takes a little fiddling to get the proper technique down but once you can replicate the frequency you'll know you're doing it right.
I've used the app from Gates a few times: Carbon-Drive
But like @ronski, I've mostly relied on the 5mm hex key trick.
Brad the bike boy has some other great videos too: here
  • Like
Reactions: 1
I've used phone apps before and found them a bit hit and miss, the Gates one being the best of a bad bunch IMO.
I now use the program written by JP of JPDiag/DucatiDiag fame, a cheap lavalier microphone on my laptop with this works great. It's the program at the bottom of this page called Courroies (belts in English): Download page
  • Like
Reactions: 1
After reading all your posts I think I will stay with the 5mm hex key method. Cheers
