I have a 2014 monster, and was looking to get a throttle spacer to take up the slack, however it is not listed on the site. Only for a 2016 up. Anyone have any information as to if one of the others will fit my bike? Thanks for the help.
Throttle spacer was more of an issue on the updated throttle on the newer monsters...the early ones should be more concerned with breaking...if you ever get a check engine light....try and change rider modes...if you can't...replace it....it gets worse at some very inopportune times
I have a 2015 1200s,and the delay in pickup annoyed me,made it difficult to pick up the throttle out of slower corners,like you I’d hoped to find a spacer kit but not made for the pre 16 models,so I took the throttle assembly apart and glued a piece of old credit card to the throttle tube peg, filed it to size and used some heat shrink to seal it all up,the result is a much more responsive throttle that now is easier to ride,be aware that the spring in the throttle assembly can cause a bit of fun and games when reassembling but a bit of patience and perseverance will sort it,I also have a Jetprime throttle/kill switch assembly with the same modification but I’ve yet to fit that…..hope this helps(y)
