I have just purchased a "w" reg 2000 600 monster with a very rough throttle action on stripping the throttle down while replacing the bars for some far lower ones I noticed a few strands of wire protruding which assume is a frayed cable causing it to stick open and extreme stiffness.
My main question is will the 750 monster throttle cable fit as they look to be the same size bike and assume the length should be the same. I ask this question as I have seen some on ebay for £15 secondhand but "good working cond" if not where would be a good place to be to get a good and cheap replacement?
Any suggestions appreciated plus any suggestions on how to replace them on the carb side of things as it seems quite tucked away!
Thanks in anticipation.
