the throttle cable is in the way of the mirror post, so I can't rotate the brake to a comfortable angle.
should I try and drill a new hole or grind the darn pin on the throttle housing?
thanks
Rob in Hoston
well now you just have me curious!
Bad experiance as in the throttle coming off or grinding a little thumb along with the pin :)
Yes just drill a new hole. You don't want the throttle assembly spinning on the bar. Plus it's a lot easier to drill a little hole than get in there to grind off the pin.
Same on the other side with the nub on the switch. I see a lot of people talk about knocking the nub off, but again easier to just drill a new hole.
