Through years of advanced research in battery electronics and electrochemistry, CTEK has developed battery chargers with superior technology that save time, money and aggravation by maximizing battery life and performance. CTEK does this by using a patented multi-step charging process: 1. Desulphation 2. Bulk 3. Absorption 4. Pulse. Ultimately what this means is that CTEK will efficiently bring the battery up to charge then shut off completely. The charger then monitors the battery and kicks in more charge when needed. This method is proven more efficient than a typical trickle charge.
In addition, CTEK has many built-in safety features that can not only save the battery, but also you and your vehicle. These chargers are splash-proof and weather-proof, so they can be left in the garage or even outside. On top of that, they are impossible to connect incorrectly. The patented technology protects against sparks and keeps your onboard electronics safe even in the presence of a power surge or lightning strike. All of these features make CTEK the most recommended charger in the world. For more information or where to buy, visit www.CTEK.com.
