Hey guys,
I'm about to get some SpeedyMoto Framesliders installed (they're in finally!) and I was just wondering - is there actually any downsides of installing them?
1) I know for some bikes with fairings you have to drill a hole in the fairing - Monsters have none so I assume there's no "damage" that needs to be done and removing them leave no mark.
2) I know that part of the sliders are installed on the engine chasis of the bike - I see the exact bolt where it would go and it's pretty clear of my knees and my legs as I walk the bike. That's really the only thing that I care about.
3) I know in a situation where if I were to go down in the grass or something else softer than concrete the sliders would actually have a negative effect, plowing into the ground, and stopping the bike quicker - perhaps throwing me off in the process. Am I wrong here? Either way it doesn't matter since I pretty much stick to the city and expressway.
Let this be a thread on posting Q&A's on sliders and if you got them installed and have pics post'em.
Cheers.
sliders are great. be very careful tapping new slider bolt through front engine mount. managed to mung mine pretty bad: had to order new bolt ($75 mistake). make sure u support motor & keep holes aligned. torque to spec & ride on
Most axle sliders eliminate the possibility of using certain rear wheel stands, such as the Pit Bull. It's an either/or situation because you need access to the hole to use those kinds of stands. I know that your question is about frame sliders, but often times, that leads you to axle sliders as well, at which point you would need to consider this.
In your #3 fear, the bike will frequently slide off the pavement and flip when it digs into something soft like grass, doing lot's of damage. I don't use them for this reason.
Drop the bike once and the sliders will pay for themselves. I have them mounted on the front axle, mid-frame, and rear axle. The T-Rex rear stands can lift the bike using the sliders OR using the swing arm (if you have the M696 with the dual-sided swing arm). I purchased the "Motovation" sliders and had no problems with installation. The engine bolt slipped out nicely (be sure to place a jack under your engine and just lift it enough to take the weight off). The sliders are a very good quality. Quick shipping, great price. Hope I don't have to use them.
Thanks guys. I ended up getting the SpeedyMoto frame sliders, professionally installed for about $200 including labor.
