·Being new top this, what oil are people running, and does it really matter as long as its a good quality sytnetic?
I use Mobil 1
I use Mobil 1
Clingability- is that a technical term? I'm not being sarcastic, almost all my riding is short trips and I need something like that. Are you referring to a narrower viscosity range with temperature, so that synthetics stay in the engine longer after shutdown?The only reason that I use synthetics is because of the resistence to heat breakdown & the "clingability" for cold starts.
Thanks. Can you go into any more detail? Like, what tests? Any brand names? Do blends have any clingability?From the tests I've seen, it seems that most synthetics cling to the metal parts better than dino
