I looking to replace the Termignoni silencers on my '15 1200S and I have found another pair that look good, have the same part number but show a different angle. Mine shows 24 degrees and the other ones are 15 degrees. Both are on 2015 1200S
Does anyone know what those figures refer to?
Ian
I would assume the angle the pipe bends just before it splits to the two mufflers. Maybe you are seeing the difference between the race ones and the homologated ones. Why are you replacing the Termis?
I'm replacing or rebuilding the existing Termi's is that they were damaged. My bike is a salvage and this is part of the damage. I have one good used silencer (upper) so I think I'm going to have to dismantle the damaged one and switch out some parts etc.
I'm going to recondition the surfaces with a sealant while I have them apart.
Ian
