·Their must somthing better than those plastic plugs? Ive seen shootgun shells . any better ideas?
I put some silicone on the portion that inserts into the frame (to eliminate and vibration) and there are two small set-screws on the bottom (one on each side).desmodevil said:[clap] how is it held in place?
I kinda like that. Good call.TurboMonster said:I had a replacement tube made to loop around the open frame holes, like a bumper.
I drew up eight different design ideals...
http://www.turbomonster.com/johnson/TailChop/MonsterTailChops.pdf
Production Photos...
http://www.turbomonster.com/BillJohnson-MonsterProduction.tpl
The short answer is "Yes", but you have to made some other changes...FatherKind said:Can you do an exhaust that will run up under the seat?
