1 - 10 of 10 Posts
· Registered
Does anybody know if it is possible to switch the oil temp display on a Monter S4 from Degrees F to Degrees C?
I struggle to work in F. I'm from England Originally, brought up with degrees C.
· Registered
I think if you push and hold the right button for a second your two it will change. If you just push quickly and let go it will change to clock. Once on clock if you hold it for a few seconds it will start blinking so you can ajust the clock, so I think if you just hold it while it is on temp for a few seconds it will switch between F and C. Not 100% on that.
· Registered
· Registered
Just tried the 'hold the right button down' theory.
Doesn't work, it just goes into 'clock setting' mode.
· Registered
Thanks for the feedback guys.
Very Useful Demofo :p ;D
Guess I'll have to work on my mental arithmatic.
Any idea what Temp the fans come on? Just got back from a ride, and saw 215 sitting in traffic. Fans were not on at that temp.
Oh and did I mention, man I love this bike!!!! Duc's Rule
· Registered
Fans are supposed to come on at 215 deg.F. Depending on the calibration of the thermosensor, it may be a little higher or lower.
If it gets over 220 and the fans don't come on, something's haywire and should be checked out.
They are very quiet, and don't flow a lot of air, so I have to take a good look at 'em to see if they're running. Got used to fan on my dad's KZ1300, sounded and felt like a freakin' Cessna when it came on.
Nice to hear you're happy with your S4.
Changed your battery to a Yuasa yet?
· Registered
Discussion Starter · #9 ·
Thanks for the info, and oops better update my profile as I have indeed changed to a yuasa. Thanks to all the good advice here.
1 - 10 of 10 Posts
