anyone know if a '99 M900 swingarm can replace the one on a '99 M750...direct swap?
i hear that most things are interchangeable from the 750 and the 900...
any info would be great!
Thanks in advance
i think that sets a record for the fastest response...
Anyone know what a used one would go for dollar wise?
S
i've seen steel ones go for about $100 used.
i sold a brand-spankin new aluminum one (for '02+ models) for about $250 last summer.
easy way to tell if you're only looking at pics is that the holes in the front 1/2 of the swingarm that the shock mounts to and the rear cylinder's header passes through will look smooth/rounded on an aluminum unit cuz the front 1/2 is cast. on a steel unit, that area looks more boxed/industrial cuz it's all welded box tubing.
this looks good but who knows what this guy's reserve is?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2463933492
this looks reasonable but you're not getting a shock (who care?!)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2464584210
Discussion Starter #5
thanks for the info strati...would I would really like to do the upgrade...i guess it would shave some weight off...
i will look at those links...
i already have the shock..so...hmmmmm
L8
S
i also like that both of those swingarms have spools (for a rear stand) built in. good stuff. the rear stand i use has "pads" that slip under the swingarm which is plenty secure, but can obstruct rear wheel rotation if i don't place it just right.
